Bobcat 863 F series engine fuse blowing
Axel
Hey all!
Been dealing with the engine fuse blowing for a while now.
Sometimes I can run it for a bit before it does.
sometimes it won’t even start, just turns over.
‘one of the times it wouldn’t start I unplugged the parking lock solenoid and it started fine. So I replaced the solenoid and it ran for a day. usually when I mess around inside it’ll run for a bit so it makes me think wiring.
I’ve searched seemingly very thoroughly for wires shorting(especially wires that move with control movements) but nothing yet.
Whatever it is it‘s beginning to appear increasingly likely to be related to the tilt and lift.
haven’t yet had it blow when just driving. but today it was obviously doing it when using tilt/lift.
It usually sounds like the engine is slowly stalling out. Slower than if I just turned the key to off.
Any thoughts?
why might tilt/lift cause blown engine fuse if the tilt/lift linkage doesn’t touch any wiring when operated?
