Bobcat 863 backhoe mounting kit - trailer balls
BobCav
I have recently purchased a Bobcat 835S backhoe attachment. It has side-shift and in-cab control, but the arm and stick is similar to the 811 backhoe. It looks like the one in the pictures below:
It has two trailer-ball couplers, that is to be connected to two trailer-balls mounted on the skidsteer chassis, in the position marked in the picture below (not my machine):
I have a Bobcat A220. As I understand, the A220 is basically a 863G skidsteer with the all-wheel steer system added. Hence, I think the A220 and the 863G shares the same upper chassis.
I have called the Bobcat distributor in my country for a trailer-ball mounting kit for the A220, and they claim it does not exist. Not even for the 863 skidsteer. I find that hard to believe.
Do anyone know if there exists a backhoe mounting kit for putting the trailer-balls on the Bobcat A220 or Bobcat 863 chassis?
If it helps, I think you would use the same kit, if you were to mount a 911 backhoe on the 863 skidsteer.
I really need to get the backhoe mounted, and would prefer a bolt-on solution.
Thanks in advance,
Casper
Why not just buy two trailer balls the right size and bolt them to the machine. If the 220 doesn't have brackets then make up two and weld them on. Bobcat told me that it was impossible to mount a 811 backhoe on an S185 so I fabbed up some mounts and did it anyway.
