Bobcat Skidsteer Forums
Bobcat 863 Arm Control Problem
Reply to thread
Message
<blockquote data-quote="Bobcatdan" data-source="post: 60380" data-attributes="member: 7339"><p>5 blinks is acturator fault. Start by switching the lift and tile acturator connectors. This will reverse the control. If it kicks out when you move the right handle now, you know it is an acturator. Yours is if not repaired once, is probably the pain in a butt early style. It will be updated to the new style. Also check to see if the control vavle is leaking, hydraulic fluid will wreck the acturator. Have fun, I hate those early ones.</p></blockquote><p></p>
[QUOTE="Bobcatdan, post: 60380, member: 7339"] 5 blinks is acturator fault. Start by switching the lift and tile acturator connectors. This will reverse the control. If it kicks out when you move the right handle now, you know it is an acturator. Yours is if not repaired once, is probably the pain in a butt early style. It will be updated to the new style. Also check to see if the control vavle is leaking, hydraulic fluid will wreck the acturator. Have fun, I hate those early ones. [/QUOTE]
Verification
Post reply
