Bobcat 853h
steveburrough
I have installed the rear stabilizers after much work. The left stick center button will raise the stabilizers. I can not get them too release. Could this be a problem in the switch, or is there some hydrolic valve issue??? These same stabilizers have been used on this machine previously. Any ideas???
I believe they are controlled by a diverter valve off the main aux hydraulics. If you don't use your aux hydraulics very often or ever, it is possible the stems are sticky causing the erratic operation.
