Bobcat 853 parts
wmodel1897
I have a bunch of 853 parts for sale four axles, four sprockets with chains. Two gear cases. Two drives. lift cylinders. rear door. cab, lift arms. The machine was burned. The cab shows burn but not warped or bent. The fire didn't get to the drives and axles. The drives should be ok, they were using it when they caught it on fire. Also have the izusu engine out of it. It was scorched but I have opened it up and the bearings and rings and pistons look fine. New head gasket new valve springs. it still had coolant in it. located in Montana
