My 843 has the front right wheel slipping. I noticed it when I was backing up a hill last summer, it would start to slip and chatter some. The rear wheel was still engaged. The same wheel was also leaking at the axle seal, so I pulled it out last night expecting the splines on the axle shaft to be bad, and they looked great, no issues tight and clean. Last winter, I rebuilt both gear cases, all new chains, chain guides, rebuilt that side pump, Like I said, the rear would spin, but the front would not. It only happens under load, but then one it starts, it seems to easier to do. The bearings seemed good and no play. I did not check the chain tightness before I pulled the axle out. Before I replaced the chains, they were almost hitting the bottom of the case. I put 2 new chain guides on as well. Is it possible the chain is slipping? The chain would have to be really loose for that to happen. I looked at the rear sprocket the best I could with a camera, and it looks fine. I don't see any missing teeth or cracks or wear for the area I can see. I want to try to drain the oil and put the axle back in with the old bearings to see how much slop is in the chain. Is there something I am missing here? Anything else I should be looking for? One piece axle, sprocket welds look good.
