Another chapter in my ongoing 825 adventure. The bottom pan under the engine fell off. The fuel tank also fell out and was dragged for a bit. There did not appear to be any damage to the fuel tank. I drilled out and re-threaded the bolt holes for the bottom pan, put things back together and restarted the machine...for about 30 seconds.. then the engine died. I have tried manually pumping but can't get the engine to catch. I did not attempt to reconnect the fuel gauge wires, the gauge has not worked for some time now. The fuel hoses (2) appeared to remain attached. Is it possible that I have pinched the fuel hose will re-installing the fuel tank? Should I continue to pump and attempt to start. I am afraid to run the battery down., Any words of wisdom?
