Billyboy102070
- Joined
- Sep 5, 2015
- Messages
- 8
Ok so the kid using my 825 said all the sudden thr left control arm went limp, and now the left tires won't spin. Do I have to take apart the hydraulic pump to where the control arm enters I ?
When you say linkages, which? I am new to the machine, a quick learn b it need specifications. . Also anyone with an 825 that needs pages from the service manual or parts manual, I have both.Check the linkages first, make sure it's all connected, if it is, time to opent he pump up and see what's up.
The linkages between the pedal and the control block. There will be bushings and pins that are at the pivot points.When you say linkages, which? I am new to the machine, a quick learn b it need specifications. . Also anyone with an 825 that needs pages from the service manual or parts manual, I have both.
