Bobcat Skidsteer Forums
bobcat 773 turbo oil pressure light comes on
Reply to thread
Message
<blockquote data-quote="deck60" data-source="post: 91183" data-attributes="member: 2281"><p>so I have been gathering parts for this I had bought a head gasket a here a while back just to have in case I needed it I made the lift to remove engine and bought a oil pump and pan gasket now the strange thing I have been loading hay big round bales to sell about 18 per load well on Wednesday I loaded what I was considering to be my last load before I tore it down after loading the bales i would usually get the warning light just before I was done and it would be at 21psi when I was done I looked at the gauge and it was at 50 psi full throttle and idle about 32psi so i used it for a hour or so doing other stuff and it was the same I started it today and no issues I am going to pull it in the next couple of weeks any one have any idas of what it could be screen plugged ??? pressure relief stuck partly open I am baffled to say the least I have a manual oil pressure gauge installed as to monitor what is happening</p></blockquote><p></p>
[QUOTE="deck60, post: 91183, member: 2281"] so I have been gathering parts for this I had bought a head gasket a here a while back just to have in case I needed it I made the lift to remove engine and bought a oil pump and pan gasket now the strange thing I have been loading hay big round bales to sell about 18 per load well on Wednesday I loaded what I was considering to be my last load before I tore it down after loading the bales i would usually get the warning light just before I was done and it would be at 21psi when I was done I looked at the gauge and it was at 50 psi full throttle and idle about 32psi so i used it for a hour or so doing other stuff and it was the same I started it today and no issues I am going to pull it in the next couple of weeks any one have any idas of what it could be screen plugged ??? pressure relief stuck partly open I am baffled to say the least I have a manual oil pressure gauge installed as to monitor what is happening [/QUOTE]
Verification
Post reply
