The machine actually locks up, after it runns awhile and will not travel. All the lights will go off. When I check for codes, it says NONE. It is a G series, not sure of year, s/n # 517611148. If you could help that would be great. Have tried all troubleshooting with theBICS system.(standard).First off what year is this machine. Is it a C F or G series.
Is the fuel shut down solinoid on the pump failing to hold the shut down lever in the run position and this is why it is stalling.
Could be a bad relay, or a dirty fuse causing a loss of ower flower to the above solinoid causing it to stall
