Just bought the machine a few months ago and the coolant temp gauge needle never raises above the full cold mark. I also have a coolant temp warning light on. I checked the fuses, i checked the coolant sensor at the thermostat and i found no power to the sensor. I pulled off both control panels and i didnt see anything loose, broken or corroded at the coolant temp gauge, at the ignition switch and at the warning light cluster. I cant seem to find the correct wiring diagram. Serial number 519011159 Thanks for any help. I dont like using it without knowing the engine temp. Scares the **** out of me.
