javelina80
- Joined
- Oct 15, 2012
- Messages
- 8
Hi I am new to this forum, but can't seem to find what I am looking for when doing a search or contacting any dealers. A few weeks ago my 763 started to lock up and 3 of the 4 BICS lights would constantly flash. The battery light would stay on. Error Code 03-10. I have a service manual for my unit so I checked the voltage out of my 55amp alternator, and found it to be out of range high... 14.7 volts at idle. (manual says, "The voltage must be higher than 13.5 volts but lower than 14.7 volts at 70 degrees F"). I replaced the alternator and battery per recommendation of a dealer. The unit operated fine for a couple of days, sat for a little over a week, and now is doing the same thing, but only putting out 14.5 volts. 14.5 volts according to the manual is within spec. On occasion I will get an 03-11 code (voltage extremely high), and the battery light will flash. Voltage again is within spec, but I am at a loss for what to do. I have checked grounding connections, and cleaned them, cleaned positive connections. The dealers only help is bring it in. Out side of this I need some help. Anyone have any ideas?
