Bobcat 753G w/cab and upgrades
Darb1234
Please help!!! I am new to your site and am in big trouble. I have had this 753 for 2 years and all was well until rodents ate the wiring in the box on the 1812 snowblower attachment and the harness in engine compartment. I replaced all harnesses with new including the main 14/7 pin harness from front to back. All snow blower harnesses are new also. I started blowing snow and all was wonderful, then darkness came and I turned on the wiper,heater and lights. A few minutes later the bobcat slammed to a stop and just about put me through the door. All the lights are flashing on both upper panels. The unit will not restart until it sits and seems to reset for 10 minutes or so. Then it runs fine for a few minutes and SLAM! dead again....please help!! Thank you.
I take it the engine stops and the park brake comes on? or just the park brake.Doesitdoitif your are not running the blower? Finaly since its a 1812 I take it the blower plug is conects to the 14 pin plug on the harness?
I don't know if it does it or not with the blower off. I haven't moved it far enough yet to see if it happens when not blowing snow. Yes, the brake comes on when everything dies but the flashing lights. I can use either plug for the blower but am currently using the 7 pin. (Recommended in book on snowblower).
Okay, I just had it running for the last couple hours on and off. I am guessing that possibly a low battery condition is causing the shutdown. There are no trouble codes present when I check for them. I will start with a battery and then go from there....my next possibility will be something to do with the seat or something in that area. Let me know what you think. Thank you!! By the way, if the battery was getting bad would it show up on a code? Thank you again.
