Bobcat Skidsteer Forums
Bobcat 753G Advice
Reply to thread
Message
<blockquote data-quote="Tazza" data-source="post: 36205" data-attributes="member: 82"><p>It should not stall, lifting the rear wheels off the ground is ok, but it should keep running.</p><p>As for the grease nipple, i assume you are talking about the one on the bobtach that tilts the bucket forward and back? the grease nipple is usually inside the pin, check the end of the pin opposite the bolt. There should be a recess and it should be in there to protect it from being shered off. If its not there, someone has changed pins and not installed the correct one.</p></blockquote><p></p>
[QUOTE="Tazza, post: 36205, member: 82"] It should not stall, lifting the rear wheels off the ground is ok, but it should keep running. As for the grease nipple, i assume you are talking about the one on the bobtach that tilts the bucket forward and back? the grease nipple is usually inside the pin, check the end of the pin opposite the bolt. There should be a recess and it should be in there to protect it from being shered off. If its not there, someone has changed pins and not installed the correct one. [/QUOTE]
Verification
Post reply
Bobcat 753G Advice
