Bobcat Skidsteer Forums
bobcat 753 play in controls
Reply to thread
Message
<blockquote data-quote="Tazza" data-source="post: 47638" data-attributes="member: 82"><p>You won't damage the pump, it would be a linkage somewhere. Like Ron and Fishfiles have pointed out, check the linkages and all connections to the pump. Even check the alloy arms that bolt to the pump are tight. They should not be able to move up or down. They have a square hole in them that the shaft slides into, the bolt comes loose and they wollow the alloy out.</p></blockquote><p></p>
[QUOTE="Tazza, post: 47638, member: 82"] You won't damage the pump, it would be a linkage somewhere. Like Ron and Fishfiles have pointed out, check the linkages and all connections to the pump. Even check the alloy arms that bolt to the pump are tight. They should not be able to move up or down. They have a square hole in them that the shaft slides into, the bolt comes loose and they wollow the alloy out. [/QUOTE]
Verification
Post reply
