Bobcat Skidsteer Forums
Bobcat 753 no reverse on right side only.
Reply to thread
Message
<blockquote data-quote="Tazza" data-source="post: 53988" data-attributes="member: 82"><p>You can swap drive motors from side to side to see if its a motor or not too.</p><p>The relief valves are both top and bottom of the pump. I don't know what one does what though. Knowing your luck, it will be the one underneath. If you look at the pump, you will see round bolt looking things with allen heads, but they are about 3/4" round. They will be screwed into the middle part of the pump where the steering levers go. There are two on one side, two on the opposite side. One for each large hose coming out of the pump.</p><p>A bad drive motor seal could be the cause. Don't buy a new one before opening it up and inspecting it.</p></blockquote><p></p>
[QUOTE="Tazza, post: 53988, member: 82"] You can swap drive motors from side to side to see if its a motor or not too. The relief valves are both top and bottom of the pump. I don't know what one does what though. Knowing your luck, it will be the one underneath. If you look at the pump, you will see round bolt looking things with allen heads, but they are about 3/4” round. They will be screwed into the middle part of the pump where the steering levers go. There are two on one side, two on the opposite side. One for each large hose coming out of the pump. A bad drive motor seal could be the cause. Don't buy a new one before opening it up and inspecting it. [/QUOTE]
Verification
Post reply
