Hi, i bought a use bobcat 753 older model and had to fix a few things... had problems with my shutoff solenoid and got it fixed thanks to this forum. while i was working on the solenoid problem i found 3 lose wires/plugs that are not pluged in into anything and i dont know where they go... maybe you guys can help me... here is the first wire of the 3, the other two come later when i get home: http://tinypic.com/r/264ic1f/5 also when i put the key in run position it shows me the hours, fuel 2(bad fuel sender, will get the sender on friday and replace it) then glow and then it shows me C-7 what is c-7 standing for? is it a error code?
