Are you referring to the spool valve that has lift, tilt and auxiliary spools mounted to the vertical wall below the throttle lever? If this is what is ‘trashed’ then there are shops that re-chrome the spools and re-machine that and the valve body back to as new as I had one done thirty years ago here in Australia.I have bobcat 753, the bucket leveling valve is trashed. Bobcat cant locate one so options are limited. Had someone suggest using a generic valve e body from a hydraulic shop. Thoughts. Think it would work?
