bobcat 753 aux hydraulics control in right joystick
clydesdale169
Having no luck searching for the switch inside the handle with the contacts that control aux hydraulics. It has 4 wires connected to it, flat piece metal that fits in the right hand joystick with 3 push buttons that operate your flow of hydro fluid. Does anyone have experience or knowledge how to retrofit maybe with a newer model. Any suggestions on where to find a used part as well. Not having any luck. Thank you!
I don't like your luck with getting a used one, bobcat don't have any available?
Not sure why there are 4 wires, unless it's ground, left, right then the other is the trigger switch?
If it's that setup, you could always get a toggle switch that has spring back to centre and retrofit it to your handle?
