I am having problems with a tilt issue with a Bobcat 751. So to let you know where it is, arm will raise up and down, will travel no problem, starting up the machine I can tilt up, but cannot tilt down. As soon as I try to tilt down it will lock out. The valve control light will go out. Checked fluids... good to go Swapped actuators... good to go Swapped connectors on actuators, problem then changed to the arm (would lower but not raise) this changed control, the bucket would tilt up and down then, so the hydraulics worked as they should. Thoughts?
