Bobcat 751 remote hydraulics don't work
diver94
New member, I appreciate the help. We have a 751 Bobcat skid loader that we use on the farm. Don't use the remotes often, maybe once a year. Worked fine during last use. Will not work now. Green light on the right side comes on when I push the button, and will go off when I push it again. When on, nothing changes, no clicks, no sound of anything engaging, just nothing. Bobcat has been out to service, earlier this year, and fixed a hydraulic issue that caused a massive leak, and caused all the functions to quit. After the service everything worked fine, but we didn't check the remotes at that time. Any thoughts? Thanks
Being sitting for some time, the stems for the aux hydraulics can stick.
I'd start by lifting the cab, removing the nuts holding the coils to the control block. Activate the aux hydraulics with the machine running and lift the coild up one at a time, reverse the thumb switch direction and lift them again. One should pull down on each side. If that works, your coils are good and your stems are sticking inside.
If they are sticky, you can dismantle them and clean them out.
