Looking at diagram of dirive motor and do not see shuttle valve. Could that be comprised of the plug, o-ring, sleeve, spring, poppet and piston located at the end housing of the motor? Are the seals you are mentioning located on either side of the geroler? this motor is serial # 18000 and >.The oil leaking itto the chain case will be the carrier seal. The drive motor issue sounds like a seal inside the motor. That or a shuttle vavle is sticking in the drive motor.
That is the shuttle valve.Looking at diagram of dirive motor and do not see shuttle valve. Could that be comprised of the plug, o-ring, sleeve, spring, poppet and piston located at the end housing of the motor? Are the seals you are mentioning located on either side of the geroler? this motor is serial # 18000 and >.
