Im not able to find the img
Are you talking about the holes for the rectangular blocks that the steering pucks stop against? Three will be slots, one will be just a hole. The one with a hole is the one you adjust first, once you have this side set to nextral, you move to the other side.If you're referring to the bolt with the spring on the far right, it would appear that it is just a hole, as spring loading and slots don't normally go together, and zooming it up doesn't show a slot
Are you looking to replace, or sourcing one that's missing on a machine that you're building up?
straight hole should fixedAre you talking about the holes for the rectangular blocks that the steering pucks stop against? Three will be slots, one will be just a hole. The one with a hole is the one you adjust first, once you have this side set to nextral, you move to the other side.
Hopefully that is the answer you were after, if not, please give a little more detail.
but idont see an issue with letting it float alittle. if somebody slotted it they a reasonstraight hole should fixed
what I meant say was . balance plate tension bolt. not slotted. but if that what takes ? steering should be centered (no creep fwd to rev speeds =/ no more than ten feet lft or rght. in 100 FT. if this can be obtained. no worrys. NOW. sometimes wear in the stat makes this unachieavible. in that case do the best you can with what you got. but keep SAFETY IN MIND.but idont see an issue with letting it float alittle. if somebody slotted it they a reason
