Bobcat Skidsteer Forums
BOBCAT 743 QUESTIONS
Reply to thread
Message
<blockquote data-quote="Tazza" data-source="post: 40765" data-attributes="member: 82"><p>If they are worn that bad, you need a machine shop, or a mate with some gear. The ram eye needs to be cut off and a new one welding on if you don't have access to a mill to bore the hole out and install a sleeve. The bobtach, you can grind the old bosses out and weld new ones in, again, a machine shop can make them.</p><p>Sadly it won't be a cheap fix if you don't have the gear or know someone that does.... I have done this repair a few times, but i have all the gear to do it. It works really well, worth the time and effort.</p></blockquote><p></p>
[QUOTE="Tazza, post: 40765, member: 82"] If they are worn that bad, you need a machine shop, or a mate with some gear. The ram eye needs to be cut off and a new one welding on if you don't have access to a mill to bore the hole out and install a sleeve. The bobtach, you can grind the old bosses out and weld new ones in, again, a machine shop can make them. Sadly it won't be a cheap fix if you don't have the gear or know someone that does.... I have done this repair a few times, but i have all the gear to do it. It works really well, worth the time and effort. [/QUOTE]
Verification
Post reply
