U uffda Well-known member Joined Nov 12, 2010 Messages 99 Jun 1, 2019 #2 I want to take out the pivot pins but not sure how to go about it. It is welded on one end. Do you remove the bolt and take out the grease zero and use a small punch through the hole to tap out the pin?
OP OP U uffda Well-known member Joined Nov 12, 2010 Messages 99 Jun 1, 2019 #3 Sorry, I meant the pins with the large bolt screwed into the end, grease zero on the other end.
O oracle_of_ferndale Well-known member Joined Feb 12, 2013 Messages 78 Jun 2, 2019 #4 uffda said: Sorry, I meant the pins with the large bolt screwed into the end, grease zero on the other end. Click to expand... remove the bolt and tap the pin back into the bushing. the arm and the bobtach will separate and you can pull the pin out from the front.
