Bobcat Skidsteer Forums
bobcat 743 few aftermarket part numbers
Reply to thread
Message
<blockquote data-quote="mattyc5094" data-source="post: 39755" data-attributes="member: 4834"><p>******BOBCAT 743 KUBOTA V1702*******</p><p>FILTERS</p><p>OIL FRAM - PH16,PH43 HASTINGS - LF196</p><p>AIR INSIDE FRAM - CA255754 HASTINGS-AF631</p><p>AIR OUTSIDE FRAM-CAK253 HASTINGS - AF129K</p><p>HYDRAULIC FRAM -P6884, HASTINGS -HF719, BALDWIN – BT8861</p><p>DRIVE CHAINS #80H DIAMOND 14,500 (2-10' lengths will do all chains).</p><p>REDUCTION BOX BEARINGS SKF - BR3720, (2) LM501310, (2) LM501349, JLM506810, JLM506849</p><p>SEAL SKF- CR25713</p><p>AXLE BEARINGS TIMKEN – LM104949, LM104912 (2 of each per axle),</p><p>SEAL NATIONAL - 40301S</p><p>WHEEL STUDS 9/16-18 DORMAN – 610-380</p><p>WHEEL NUT 1" SOCKET DORMAN – 611-053</p><p>HOSES TILT CYLINDER (2) ½" 3500PSI 18" JIC-10 M/F</p></blockquote><p></p>
[QUOTE="mattyc5094, post: 39755, member: 4834"] ******BOBCAT 743 KUBOTA V1702******* FILTERS OIL FRAM - PH16,PH43 HASTINGS - LF196 AIR INSIDE FRAM - CA255754 HASTINGS-AF631 AIR OUTSIDE FRAM-CAK253 HASTINGS - AF129K HYDRAULIC FRAM -P6884, HASTINGS -HF719, BALDWIN – BT8861 DRIVE CHAINS #80H DIAMOND 14,500 (2-10' lengths will do all chains). REDUCTION BOX BEARINGS SKF - BR3720, (2) LM501310, (2) LM501349, JLM506810, JLM506849 SEAL SKF- CR25713 AXLE BEARINGS TIMKEN – LM104949, LM104912 (2 of each per axle), SEAL NATIONAL - 40301S WHEEL STUDS 9/16-18 DORMAN – 610-380 WHEEL NUT 1” SOCKET DORMAN – 611-053 HOSES TILT CYLINDER (2) ½” 3500PSI 18” JIC-10 M/F [/QUOTE]
Verification
Post reply
