Bobcat 743 coupler lubrication
OLE4
How do you grease the universals on the driver coupler. Does the engine have to be pulled or can you reach it with the cab up? I was not able to see them when the cab is raised as it must be in blower housing or just outside of it. Is this difficult to do? Thanks for any help.
You will need an extra long grease gun hose and twist it round through the blower housing, its not easy but can be done. Worst case, you may need to pull the engine, but that's a last resort. A helper to slowly rotate the engine is an asset too, you will need them to turn the engine to get the grease nipples in the right location.
