Hi, I have a 742 that I'm changing all four axle seals and bearings on. Once I got into the chain case, I noticed one of the bearings from the gear case extending into the chain case. Figured you have to remove the cap (P/N 6565289 ?) to either tighten the bolt, or replace it if broken. What is the best way to remove that cap? It does not seem threaded, yet does not seem just pressed it to place. I have removed the sealant from around it, no help. Thanks for the help, and great Forum.
