Bobcat Skidsteer Forums
Bobcat 741 (same as 743) pintle lever sloppy & weak left side
Reply to thread
Message
<blockquote data-quote="Tazza" data-source="post: 98845" data-attributes="member: 82"><p>There is no cam in it, they have a poppet and seat, as the resuure rises, it pushes the poppet up to allow fluid to pass by.</p><p>I'm not sure why the lever is moving on it's own, if the centering is not adjusted correctly, the steering lever can rock back and forth, i have had a machine that this happened to. I adjusted the neutral and it was fixed.</p><p>With the cab up, you should be able to hold the pintle levers (where the steering sticks attach) and jiggle back and forth and they should not have any play if adjusted correctly. If you push hard enough they will move the spring.</p></blockquote><p></p>
[QUOTE="Tazza, post: 98845, member: 82"] There is no cam in it, they have a poppet and seat, as the resuure rises, it pushes the poppet up to allow fluid to pass by. I'm not sure why the lever is moving on it's own, if the centering is not adjusted correctly, the steering lever can rock back and forth, i have had a machine that this happened to. I adjusted the neutral and it was fixed. With the cab up, you should be able to hold the pintle levers (where the steering sticks attach) and jiggle back and forth and they should not have any play if adjusted correctly. If you push hard enough they will move the spring. [/QUOTE]
Verification
Post reply
