Bobcat 732 Hydraulic fluid drain
17mvbobcat
Ok I have an old 732 I am doing some work to and wondering how do I drain the hydraulic fluid? It has been a long time and I have never done it Thanks
    2.1 MB
The easiest way is to connect an open hose to one of the aux hydraulic outlets, place the open end in a suitable receptacle, start the motor, actuate the aux hydraulics, and allow the machine to pump it out at idle. Once the hose starts to sputter, shut the engine off.
Sold mine year before last, but I think the main reservoir has a 1/2 drive drain plug. The reservoir tank is large, square, and located at the lowest point on the machine although I can't recall which side you access it from. Under the seat probably.
