Decathlete45
- Joined
- Jan 30, 2022
- Messages
- 2
Have an older Bobcat 721 with the Deutz F2L411. I’ve swapped over to a F2L511 but am having trouble aligning the U-joint to the splined shaft on the Hydraulic pump. Is there any trick to this?
So far, we’ve had a pair of channel locks on the u joint rotating it slightly while someone else pushed it in. It seems to square up and rotate a little like the splines line up but then when I attempt to push it in the rest of the way, the joint cocks and doesn’t go on any more.
Any help or suggestions would be appreciated.
