I got water in the hydraulic fluid of a Bobcat 720 so was changing out the fluid by running it out the accessory hose. Unfortunately, I ran the pump dry. I don't know hydraulics, but the concepts *seem* easy enough. Famous last words, eh? I hoped that topping up the reservoir and radiator might get the fluid where it needs to be. It didn't. I replaced the filter, filling the new one before screwing it on. I tried filling through the openings on the top of the pump. I figure I need to crack open some/all of the output lines from the pump, but... I don't know the routing! I'm not sure which are "in" and which are "out." I've tried to figure out which Vickers pump is in there and look for a web resource that can tell me which is which. No dice. The only numbers I see on the pump (which has several thick coats of paint to try seeing through) are the patent number and a six-digit which does not come close to the model numbers. I figure it is a serial number. Any suggestions?
