Bobcat 645 pve19 / ta1919 problems pintle leakage
Dr_doAbit
Helllo. 5 months ago i replaced the pintle seal and oring of the pintle on my bobcat 645. It did ok for a bit and then started leaking again, at first drips an a couple a weeks ago it sipped out. I did the samething agan yesterday, it stopped leaking, agan... When i had the pintle seal off id did look and feel arround and there is no sharp edge or so to be found on the pintle rod or on the spacer. The iring seemed again fine but changed it out again to be on the safe side. When closed up again it looked ok and overnight there where no leaks. But today after 30 mins of use it started leaking again.... I have no idea what is causing this. Does someone have a sort off the same experience whit this seal , it is leaking on the seal side, the oring is keeping up fine. (Could it have something to do with the spacer and or bearing ?) Thx in advance.
