Bobcat Skidsteer Forums
Bobcat 643 hydraulic problems
Reply to thread
Message
<blockquote data-quote="Bobcatt643" data-source="post: 95510" data-attributes="member: 12885"><p>I have the exact problem with the same machine 643. I going to change the bronz and hydro filter but Im not sure if it will work becouse my bronze filter was not so bad. From where can i see is the oil foam, from the cap of the reservoir? I have spme spots that colecting dust seems like leaks one is on the supply hose from the reservoir and Im thinking to change it. Could this noise be from dameged seals on a drive motor?</p></blockquote><p></p>
[QUOTE="Bobcatt643, post: 95510, member: 12885"] I have the exact problem with the same machine 643. I going to change the bronz and hydro filter but Im not sure if it will work becouse my bronze filter was not so bad. From where can i see is the oil foam, from the cap of the reservoir? I have spme spots that colecting dust seems like leaks one is on the supply hose from the reservoir and Im thinking to change it. Could this noise be from dameged seals on a drive motor? [/QUOTE]
Verification
Post reply
