Bobcat 642B will not turn over.
samhendrix26
We have a 1988 Bobcat 642B that will not turn over when the key is turned. The starter is good we are sure of that. When turned you just hear one single *click* then nothing. All of the lights and gauges in the cab light up. The alternator and battery are good as well. The assumption is at this point it is just a wiring problem and can be fixed by testing all the way from the key switch to the starter. Also another side note the fuses are good. Any help is much appreciated!
I'd suspect a wiring issue from the key to the starter/starter relay. The switches do go bad too.
It may even be the connector in the harness behind the seat.
