Bobcat Skidsteer Forums
Bobcat 642b oil pressure light
Reply to thread
Message
<blockquote data-quote="OldMachinist" data-source="post: 58213" data-attributes="member: 437"><p>If you have something else with a gauge on it you can swap it out to see if it reads the same. or you can hook it up to a air line that has a gauge and regulator to see if they read the same.</p><p>The relief valve is in the front engine cover. You need to pull the engine and then remove the oil pan to get to the valve.</p><p><a href="https://www.skidsteerforum.com/skid2/javascript:void(0);" target="_blank"><img src="http://i245.photobucket.com/albums/gg49/calfranch/Bobcat/642b/642B_oil_relief_zps014325c6.jpg?t=1348089742" alt="642B_oil_relief_zps014325c6.jpg " class="fr-fic fr-dii fr-draggable " style="" /></a></p></blockquote><p></p>
[QUOTE="OldMachinist, post: 58213, member: 437"] If you have something else with a gauge on it you can swap it out to see if it reads the same. or you can hook it up to a air line that has a gauge and regulator to see if they read the same. The relief valve is in the front engine cover. You need to pull the engine and then remove the oil pan to get to the valve. [URL='https://www.skidsteerforum.com/skid2/javascript:void(0);'][IMG alt="642B_oil_relief_zps014325c6.jpg "]http://i245.photobucket.com/albums/gg49/calfranch/Bobcat/642b/642B_oil_relief_zps014325c6.jpg?t=1348089742[/IMG][/URL] [/QUOTE]
Verification
Post reply
