Bobcat Skidsteer Forums
Bobcat 642 chain case removel
Reply to thread
Message
<blockquote data-quote="Tazza" data-source="post: 43087" data-attributes="member: 82"><p>I don't believe there are any in the engine bay, they are on the support plates that ware welded to the axle tubes. You will see about 5 on each plate at the axle tubes going through the main frame. These are the ones you need to remove. You will need to support the weight of the machine to allow the bolts to come out though (obviously).</p><p>Send me an email, i'll look for the pictures tonight. This way its a reminder to do it too!</p></blockquote><p></p>
[QUOTE="Tazza, post: 43087, member: 82"] I don't believe there are any in the engine bay, they are on the support plates that ware welded to the axle tubes. You will see about 5 on each plate at the axle tubes going through the main frame. These are the ones you need to remove. You will need to support the weight of the machine to allow the bolts to come out though (obviously). Send me an email, i'll look for the pictures tonight. This way its a reminder to do it too! [/QUOTE]
Verification
Post reply
