Bobcat Skidsteer Forums
Bobcat 632 problem
Reply to thread
Message
<blockquote data-quote="jerry" data-source="post: 51223" data-attributes="member: 931"><p>it is a double u joint with spacer block. If it did lock up certainly would put a lot of force on the pump depending on how well it was lined up to begin with. I had 632 3 years ago and bobcat quoted me 1000 to replace u joint, I bought parts from bobcat and did it in 3-4 hours for about 200 including new bolts. See if you can withhold payment till you pull the motor to see how much damage was done.</p></blockquote><p></p>
[QUOTE="jerry, post: 51223, member: 931"] it is a double u joint with spacer block. If it did lock up certainly would put a lot of force on the pump depending on how well it was lined up to begin with. I had 632 3 years ago and bobcat quoted me 1000 to replace u joint, I bought parts from bobcat and did it in 3-4 hours for about 200 including new bolts. See if you can withhold payment till you pull the motor to see how much damage was done. [/QUOTE]
Verification
Post reply
Bobcat 632 problem
