steinbrecher
- Joined
- Apr 28, 2011
- Messages
- 1
Hi all. I have a Bobcat 630. My original problem was I could run it for 15 minutes and the sticks would start squeeling and they would get stiff. If I let it cool down I would get the same out of it again. A year ago I read a thread on this sight that gave me hope that changing the port block filter might fix this. I did change it and it seemed to help. I think there are more problems. When I changed it there were metal filings in caught by that filter. I did clean the port block really good because of the metal filings. Something I did learn through doing that repair is you should replace the o-rings when you take that all apart. I didn't and now I need to go back and do that. I have some leaks. I just keep puting fluid in the reservior. I realize I have several problems, but where typically do the metal filings come from? Also is it worth getting a rebuild kit or do you just swap out the component? Even rebuilt components are expensive.
