bobcat 630 wont steer correctly
bobcat630
hi i just bought a bobcat 630. the problem is the right side, when it first starts up and you use it, it works okay but you can tell that the left side has more power than the right and after you use if for 15 minutes the right side barely works. and the right side makes a almost sqealing noise . i took it all apart and dont see anything wrong, i was thinking that it could be the drive pump? also was wondering where the bronze filter was.
http://www.skidsteerforum.com/DesktopDefault.aspx?tabid=54&frmView=Search&searchText=bronze%20filter&forum=1
this should show you the bronze filter, if not use the search blank for this forum.
bobcat630-I'm interested in what you find, I also have a 630 and although it does not sound as bad as yours I am noticing a difference in steering from the left to right side-please keep me posted Thanks Andy K
