Bobcat Skidsteer Forums
bobcat 630 hydraulic power loss
Reply to thread
Message
<blockquote data-quote="lucaslandscape" data-source="post: 54758" data-attributes="member: 7373"><p>Update.....k I was feeling a little adventurous so I took out the bronze filter and put a washer in the return line from the control valve also put a gauge in the port block since my idot lights dont work?.. .on start up gauge said 160psi after it warmed up it went down to 140psi went for a test bucket and seemed a little better but hardly worth mentioning.the gauge I put on the pump only reached a peak of 1500-1600 psi hard to read because it's not steady far cry from the 1950 the manual says its should be</p></blockquote><p></p>
[QUOTE="lucaslandscape, post: 54758, member: 7373"] Update.....k I was feeling a little adventurous so I took out the bronze filter and put a washer in the return line from the control valve also put a gauge in the port block since my idot lights dont work?.. .on start up gauge said 160psi after it warmed up it went down to 140psi went for a test bucket and seemed a little better but hardly worth mentioning.the gauge I put on the pump only reached a peak of 1500-1600 psi hard to read because it's not steady far cry from the 1950 the manual says its should be [/QUOTE]
Verification
Post reply
