BOBCAT 630 CARBURETOR AND GOVERNOR SETUP
chuckcnm
Hi all, I have a BOBCAT 630 that I need a little help with the carburetor and governor setup. It seems the last shad tree guy was into using clothes hangers to fix things. If anyone has some I could use some pictures on how the linkages are connected. The carb to the gov, gov control spring, choke cable and how the carb is connected to the bobcat throttle control. I have a parts book but it is not very helpful and a picture is worth a 1000 words. I sure I can figure it out but I would hate to go thru the trial and error route. the way i am reading the governor adjustment, i do not think the carb throttle is installed correctly. does the governot pull away from or push towards the carb to maintain RPM the engine is a VH4D and i think the setup number is 415666 Thanks ALL My email is [email protected]
Thank you sir, I have this informantion. I did find some pictures of my carburetor last night on the internet, a wonderful thing that internet, with those and this info you have provided I think i can figure it out, thanks again.
NO JOY, I had a chance to look at this again closer today, the attachment above compared to my carb. the throttle lever is 180 from the maintenance manual and the pictures i found as well. mine does look like the carb in the wisconsin maintenance manual. L63, even this one is not 100%. it looks just like this, but on the right side and mine is on the left.
