I have a 610 with the Wisconsin engine that quit running this weekend. The engine has no spark and the distributor does not turn at times when cranking. I can rotate the engine by hand and hold the hydraulic pump coupling from spinning. From my research it looks like there is an issue with the gear that drives the distributor. From the diagrams I've found it looks to be an intermediate gear of some sort between the crank gear and distributor drive gear that has a possibility of coming loose. I looked into the timing inspection hole and don't see any damage to speak of to the distributor gear. I figure the engine is going to have to come out to inspect it further. Is there anything else I should be looking for? I will plan on fixing that issue and then firing the motor on a stand to verify before putting it back in the bobcat. I'd also like to check the health of the motor while it out assuming there isn't any catostrophic damage. I'd probably check compression / leakdown and go from there. Are there any typical problem areas that should be addressed while the motor is out? I know it looks like the engine is leaking at the exhaust manifold so that will need to be milled and cleaned up. Are parts readily available and reasonably priced for this motor? Any guesses what a standard rebuild would run off hand? I know that's a pretty open ended question so just give me an idea if you've recently rebuilt one and what it all needed. Also can these be moved when not under power? It died next to my shed so I'd like to get it into the shed at some point in time to make it easier to work on. I'm hoping that I could shift the valve for the bucket and use a heavy duty ratchet strap to lift the bucket enough to move it. Is that possible? Thanks for your time. Benji Farr Green Bay WI
