bobcat 542b
scotchlok53
I have a bobcat that shuts down after 15 minutes of use. it has a full tank of gas but to get it started again I need to add gas it will run for 15 minutes again and shut down, does any body have any ideas could you some help, thanks
Chances are that the fuel pickup tube is broken, or has a crack near the top that will only pull fuel when submerged. It's a common problem in the 7xx series machines, so it would be the first place to look on this as well.
Hi, where do I find the fuel pickup tube?, I have located the fuel lift pump, does it come from the fuel tank? excuse my ignorance. I have been looking through the service manual, thanks for the help.
thanks for the info, you were right, that's what it was
