Bobcat 530 Governor
cats7cc
I had one of the weights that broke off in the Governor on a Bobcat 530. Can anyone tell me where to find one. Bobcat doesn't show a part # for just the weight anymore, they only show a p/n for a complete Governor. Also does anyone know what Honda motor is a direct bolt in replacement for this machine. Looking at possibly just replacing the motor if I can not find a used governor or weight for Governor.
Being an old machine, parts for the govenor may be hard to find now...
You said it broke off, i assume you have retrieved the part? if not, you will need to find it or else it could break something else.
Sorry, i don't know what engine would be an easier drop in replacement. I don't think anything will just bolt in, you would need to do some modifications.
That should be a Kohler K582. They used those motors in a bunch of things. John Deere used them a bunch. I think there were several models with the same parts just different bores. K482,k582. I think you can find a service manual on the net. If not I have one. I would check ebay for parts. Search K582
Thanks Guys for the replies. Yes I have since done some research. It does have the Kohler K582. I have since found the governor on E-bay. Yes, I may just order one from there. Yes all pieces have been retrieved. Have also found the Honda motor for this machine, it is the GX670. There is a mounting plate kit and adapter for the output shaft I believe. Also, does anyone know the size and length of the output shaft on the K582? Is the hydraulic pump chain driven? Are the rebuild kits still available for the Kohler 582?
Here us a link of the Honda I found. http://www.smallenginewarehouse.com/GX670-Bobcat540-R1.html
