bobcat 500
foton
City & State/Province
Cleveland,Tn.
The two capped off hydro pipes ,I assume factory remotes in the rear right corner of the machine. are they one non controlled pressure and one return? I am thinking about adding a bolt on grapple .
They are the auxiliary lines normally controlled by the middle peddle if you have one. Sometimes there is an auxiliary valve mounted on the right hand side brace….directional pressure each way.
I only have two pedals, I guess I will put a pressure gauge on each piped end and see what happens when I operate each pedal.
and there is no aux valve on right
I put a pressure gauge on each tube and got nothing when I moved the pedals for the bucket . Took off the floor panels and traced the tubes to a valve ,found where a pedal could be connected . I activated the valve rod slightly and got a pressure bump in the rear remotes location. can anyone describe where and how the third pedal was configured.
It's a third pedal that goes in the middle….links to the valve. You will have to find one used as they are NLA…..I have extras if you can't find one local.
ok that make sense, do you have the rod and I guess you would call it a yoke that connects to the plunger?
Sorry foton …. didn't see your response. Yes, I have everything….I'd need some pics of your valve from under the seat (front view) to verify what parts are needed but I'm sure I have everything.
ok I got some things in the way right now so give me so time to get this other stuff out of the way and I will get back . I have a email of [email protected] cell# 727 421 7072 if you want to text me some info. maybe we can speed some of this up that way.
I had some time it was not that big deal to fabricate but thanks for the offer
