bobcat 4 in 1 bucket
Dean
have recently purchased a second hand 4 in 1 bucket for my bobcat (havent picked it up yet) iwas told by a neighbour that i should remove the oil from the hydraulics so i dont contaminate the hydraulic oil in the machine, any thoughts please? if the oil has to be removed can someone explain how this is done please, best regards Dean
It's a good idea to try to remove as much of the oil from it as possible. If the machine it was on before had a catastrophic failure the oil could have metal shavings in it or if it's been sitting for a while the oil could have water in it.
I would remove the hoses and flush them with mineral spirits, then blow them out with compressed air. With hoses off you should be able to work the cylinders in and out by hand to force most of the oil out of them in to a clean container. If that oil looks cantaminated then you will need to flush them too.
Another way is to hook it up to your quick attach, remove the couplers and tilt forward and drag the bucket so it opens the clam. This will force the oil out of the rams. This will save you removing pins and what not to push the rams sticks in and out to flush what oil you can out.
I'm sure you'll love your new bucket, all my machines have 4 in 1 buckets :)
thanks for the info, will give it a go, will pick up bucket today, regards dean.
thanks for the info, will take your advice and check the bucket out thoroughly, picking up bucket today, regards dean
