Other Brand Skidsteer Forums
Kubota/Wacker Neuson/Hesston/IH/Ford/Other
Bobcat 313 - hydraulic problem
Reply to thread
Message
<blockquote data-quote="Handyfixer" data-source="post: 96703" data-attributes="member: 13772"><p>Hi guys, Thanks for all the replies and ideas. Meanwhile I've found the problem. I disconnected the pump and found out that it still was pumping oil and shaft was rotation smoothly. Then I took off the complete oil filter and when I blew into the entrance I noticed a lot of resistance, so dirt inside... bought a new one and the problem was solved. As the previous owner so connected the inlet hose to the outlet of the filter and the outlet hose to the inlet, the overpressure valve was not opening when the oil filter doesn't allow the oil to get through... so I also corrected this one. Now it's working perfect! <img src="data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7" class="smilie smilie--sprite smilie--sprite1" alt=":)" title="Smile :)" loading="lazy" data-shortname=":)" /> Thanks again for your idea's!</p></blockquote><p></p>
[QUOTE="Handyfixer, post: 96703, member: 13772"] Hi guys, Thanks for all the replies and ideas. Meanwhile I've found the problem. I disconnected the pump and found out that it still was pumping oil and shaft was rotation smoothly. Then I took off the complete oil filter and when I blew into the entrance I noticed a lot of resistance, so dirt inside... bought a new one and the problem was solved. As the previous owner so connected the inlet hose to the outlet of the filter and the outlet hose to the inlet, the overpressure valve was not opening when the oil filter doesn't allow the oil to get through... so I also corrected this one. Now it's working perfect! :-) Thanks again for your idea's! [/QUOTE]
Verification
Post reply
