Hi All, I have a bobcat 310 I have owned for a little over a year now. I have put a little over 100 hours on it since I got it so the hour meter is at 1000. Lift and tilt cylinders leak to the point I have purchased new seals but have yet to put them in. This fall during use the hydraullics would on occasion stop briefly and I would wait a minute or so and they (hydraullic pump) would kick back in and all would be fine. I checked fluids by the manual and they appeared fine which was amazing based on the amount of leakage. Kept using to finish the job until one day hydraullic pump quite working and didn't kick back in. Did some "research" on the internet added 10w30 to the chaincase as it was low (about 2 quarts) which manual said was fine instead of hydraullic fluid. After adding oil pump kicked in enough for me to cycle the lift an tilt cylinders and then quit. Been sitting in the shop on blocks since. Now that holidays are over I want to get it up and running. Starts and runs fine just wont move and seems as if the hydraullic pump wont engage. Any help or advice would be greatly appreciated. Thanks in advance.
