bob cat m500
Tomlinsondonald
was moveing dirt and working fine then started moving at a lower rate of speed ? trying to look at service manual but not having any luck..
foton
I can think of two things if you have the original variable speed drive there is the belt, then there is the clutch packs in each gear chain case.
T
Tomlinsondonald
Thanks thought that could be it I just happen to have a new belt. Clutches easy enough to adj . But the belt I think is correct is there and adj ? I have manual I'll look it up. Thanks
